Anybody ever ran holley 500 2 barrel on 604 if so how did it do/compare to the 650? Any info/help on this? Local track made a rule change and just trying to figure out what way to go.Thanks
Holley 500 on 604
I'd await a good response from Hibbard or somebody that is an expert on crate motors but I think that's too small. The math tells us that you probably wouldn't pull much past 6000 RPMs. Not enough air. Depends on volumetric efficiency and I'm not exactly sure what the VE of 604 actually is but I don't think 500 CFM is going to cut it.Originally posted by weasel27 View PostAnybody ever ran holley 500 2 barrel on 604 if so how did it do/compare to the 650? Any info/help on this? Local track made a rule change and just trying to figure out what way to go.Thanks
Matt is correct in the fact of "by the numbers" it will be lacking over 6000
BUT
we have found that real world racing the 4412 2 barrel (500) can be nearly as good as a 4 barrel
I do say "nearly" because it is lacking on those last few digits of top end power, however it is very driveable through the power band and as we all know drivability and reaction are worth more than peak power numbers
I am not saying that you should run a 2 barrel but if you HAVE to ---to meet the rules chances are it will be OK
spacer/adapter is key and air cleaner bases make a substantial difference also
Brad
Thanks for help Brad, it was a rule change so we have to run them now. With that being said what spacer/adapter would be the best and what air cleaner base? Do you think the gearing will be the same or should I have to go up or down on points to maintain my rpms? Thanks again
the HVH adapter (SS4412-2AL) will pull the hardest at low end
center it on the intake----some engines respond better in other positions (its adjustable) but we found it best in the center
there is one that did better on the upper end but it suffered on low end ------we strive for acceleration so I would stay with the HVH in most cases but if your on a momentum track with sustained mid to upper rpm let me know and I will get you another number
R2C base for sure unless your permitted to remove the choke housing then that's a different story
brad
not as much as most think---
depending on the 4 barrel combination that we are comparing to and the fuel being used----
30 peak tops
and through the racing power range its less
brad
and don't forget about drivability------
2 barrel carbs are vey drivable and what is it that really wins circletrack races?
still not suggesting that everyone run out and buy a 2 barrel ---just don't be afraid of it if your rules mandate it
brad
