I am a newbie to crate motors. I have a 602 crate. What weight and oil should I run in it? I'm thinking a 20W-50 synthetic, but I just want to make sure before I screw something up. Are there any brands to stay away from? Thanks!
Which Oil For 602 Crate?
we recommend a mix of Gibbs xp3 and xp6
Brad
20-50 won't be bad for the engine, but a thinner synthetic oil will produce less drag which = more HP and will provide longer life of your engine. We use and sell Joe Gibbs Racing oils.
I second that !! Very good oil but way overpriced !!!!Originally posted by hsracer View PostDont waste your money on Joe Gibbs oil.There are oils out there that are close to Gibbs qaulity and have high levels of zinc. Brad Penn,Mobil 1 and Pennzoil Racing oil all have high zinc. Gibbs oil is way to expensive to buy at a $15.00 1quart.
Penn,Gibbs,Shaeffer's,Royal Purpal are all around the same in Performace & protection.
All these oil's can be run for 500 laps if you :
1 Keep air filter clean after each night
2 replace oil filter every other night or 100 laps
3 Run an oil cooler
4 Keep water temps below 210Central IL Bert Transmission Rebuilder
Brian (217)201-3640
After seeing the inside of our 602 engine when it was torn apart at Hendren's Racing Engines after running it for 1927 green flag laps (we dont count caution laps or partial laps) it will be hard to convince us to ever change. The bearing looked like new (Craig was actually lining them up on the table because he thought I was going to re-use them), the nose of the cam showed NO wear and there was no sign of wear in the cylinder walls....still WAY within spec. Oh yeah, and my quick change rearend has 6 seasons on it and never even had a bearing replaced using the Gibbs Super Speedway Gear Oil.
Yes, there are other oils out there that are very good and have high zinc levels... but I wouldn't put my reputation on any except the Gibbs.
You get what you pay for and pay for what you get.
Chris, wasn't it you that new the guy that ran GIBBS all year in the car and never chainged the oil. Don;t think I would try that with very many oils either!Originally posted by Chris Steele View PostAfter seeing the inside of our 602 engine when it was torn apart at Hendren's Racing Engines after running it for 1927 green flag laps (we dont count caution laps or partial laps) it will be hard to convince us to ever change. The bearing looked like new (Craig was actually lining them up on the table because he thought I was going to re-use them), the nose of the cam showed NO wear and there was no sign of wear in the cylinder walls....still WAY within spec. Oh yeah, and my quick change rearend has 6 seasons on it and never even had a bearing replaced using the Gibbs Super Speedway Gear Oil.
My first year rebuilding crates we did about 10 engines most of which had run about 50 races on mobil 1 15/50 with regular oil changes (4 to 5 races) they all looked pretty good and had no major wear in any area. And then we had an engine come in that ran 76 races with only 1 oil change at mid season.
This engine was run on Joe Gibbs.---It was absolutely perfect inside as I recall I questioned him that he brought the right engine. It was the best I had seen, however I just figured it was a fluke and continued to recommend the Mobil.
a couple years later another customer of mine got hooked up with Chris Steele and began to run the Gibbs stuff. There wasn't much out of the ordinary for awhile until a race at Expo Speedway a big 5/8 mile track that runs in the daylight and is tuff on engines.
Anyway--- because of a hammerdown attitude by the driver on this huge track the oil temp was so high that the gauge didn't come off the peg till the next day.---He continued to run the same engine for another 30 some races winning many of them and when we disassembled the engine in the tech barn at Wythe Raceway at the Grand Nationals the only problem was the piston rings were worn out.
I am not saying that the Mobil is not a good oil but the results we have seen from the Gibbs is AMAZING
We now recommend Gibbs to everyone
Brad
Race-1 offers competitive pricing on Chevrolet Performance 602, 604 & 525 sealed circle track racing engines. Race-1 specializes in the GM CTC engines and we offer a wide variety of services specific to the 602 & 604 crate engines. Your source for Stealth Racing Carburetors! Learn from Brad's expertise in teaching, too!Last edited by brad hibbard; 04-09-2011, 08:42 AM.
If you replace it about every 400 miles you will be good and should be Much cheaper than other oils. Think of it this way.
If you run on a 1/2 mile track:
10 laps practice
10 Lap heat
40 lap feature
= 30 miles a night.
You can run over 13 weeks before changing the oil.
