Lift arm support
  • keeks
    • Oct 2008
    • 687
    Lift arm support
    Has anyone ever noticed a difference between the side mounted brace vs the brace that goes back to the axle tube? Can the side (frame mounted) support limit LR hike?
    • 14303
    Performance wise, there doesn't really seem to be a difference. There are potential bind issues with either one. Just make sure you run either one through the motions you expect .
      I personally prefer bracing it to the axle tube because it eliminates pivot points. Less points of failure/potential bind and less maintenance. And as MBRacer stated, nobody has come up with a performance reason for doing it one way or the other.
