If your running a multi leaf spring, these bars will eliminate rear steer that comes from the bow in the spring front. This can be either good or bad thing. I believe Afco still makes a cheap spring clamp, that you can pt on the spring with a wrench and dial it to your liking. Clamps at end of each leaf, front and back for solid. Just fronts or every other leaf and they don't have to be the same side to side. If I remember right solid on the right and just front clamps on the left was close. Then re arching the springs and using lowering blocks, fine tuned it. It's all about anti squat and asymmetrical loading. Putting that left rear mount on a slider can help get you some rear steer also. If you twist that spring up, you need shock to control it.
