tight in the center
  • riddle28
    • Apr 2010
    • 1088
    tight in the center
    ive got an 09 bwrc and this weekend we were tight all night when i got in the gas. When the track was fast i could put the rr in the moisture and it would kind of even out traction across the rear and wasnt as bad but when the track blew off I was way too tight picking the gas up. I raised my j bar on the frame and put some rebound in the rf and it helped but it was still pretty snug. Just wanting to see what you guys would go to at the track
  • Punisher88
    • Nov 2014
    • 495
    I wouldn't have raised the j bar on the frame. I would have raised it on the pinion. Also could move the fifth coil back. I had an 09 bwrc and had good luck with a 200 lr with about 100 lbs of bite and 400 rr. 450 left front and 350 right front. That was with a nlms sportsman motor on a high banked momentum track. Take rebound out of rr will help free up Center. Along with taking rebound our of the left front. I like to add alot of rebound to the left front when the track slicks off. I never ran below pinion on my j bar I typically ran Center and at ride height I had 8.5 of split. I don't recall how far it was up on the frame and I was extremely fast with this setup.
    • riddle28
      • Apr 2010
      • 1088
      i went up on the j bar to help scotch the car and it helped some but i was still too tight but i usually run j bar a little flatter than most. did i read that right you ran a 400 rr? lol
      • Punisher88
        • Nov 2014
        • 495
        That's correct. Lol. At EAMS it's so flat out and wide open it actually seemed to help turn the car. It will tighten it up a ton getting in off the throttle though.
        • riddle28
          • Apr 2010
          • 1088
          yea i ran there with a mod a few years ago so i could see it working there
          • riddle28
            • Apr 2010
            • 1088
            thanks for the advice tho
            • CCHIEF
              • Jul 2014
              • 399
              How long are you out of the gas at this track? What is your car like when you are? I'm thinking you need to loosen car, off the gas. Or get to where you don't have to lift..much.
                • 2020
                Is this a common issue with you and other cars you've had in the past or just this car or just this track? Reason I ask is Honestly 75% of the time it's a driver induced issue. Many times a simple slight adjustment in driving or how they are running a line can fix this. Not bagging on ya at all, it's just real common with some driving styles and can be fixed usually real easy with a adjustment by the driver.
                • CCHIEF
                  • Jul 2014
                  • 399
                  Or adjusting the idle up to 3-4k RPM for forced learning!
                  • riddle28
                    • Apr 2010
                    • 1088
                    its not super slick where youre having to back the corner way up, i looked at last years notes and i may stiffen the rf to help roll in a little better. and I always prefer a free car, and im pretty good about trail braking and keeping the rpm's up, it wasnt as bad when i could enter a little higher and diamond off but if i had to enter low it would shove the front end when i picked the gas up
                      If my car is tight when I initially get in the gas, the first thing I do is raise the bottom left bar on the frame. This will slow down birdcage indexing into the LR spring and get more rear steer in the car. This is a very effective adjustment that might help you. You might also just try putting more rebound in your RF if the problem isn't too severe. Then let the rebound out as the track gets slicker.
                      • collateralDamage
                        • Jul 2010
                        • 110
                        i like left bottom rod up a hole... or raise both right side bars on frame and see if you lose any drive. too soft on lf spring can also cause what you're describing, especially if it is chained and/or a high rebound shock....
                        • riddle28
                          • Apr 2010
                          • 1088
                          thanks guys, this definitely gives me some things to think about!
                          • FlatTire
                            • 560
                            That RR needs to become more effective. When there is moisture in the track it is more dominant and can steer the car. When it slicks off, it has less control over which way the car goes. So you need to slow down the LR reaction or speed up the RR. Im guessing the RR tire temp is lower than LR? Usually the RR isn't getting pinned down before the LR gets up which is why the car won't turn.
                            • keeks
                              • Oct 2008
                              • 687
                              So how does one slow down LR or speed up RR? Shock timing?
