Dragging the brakes
  • Roudy73
    • Jun 2016
    • 33
    Dragging the brakes
    What is a good adjustment to free up you car when dragging the brake. Seem like it just want to shove the nose in the center? Thanks!
    Turn off rf brake. A just bias to rear if running on 4 wheel brake. Quit dragging brake.
    • CCHIEF
      • Jul 2014
      • 399
      X2..... Quit dragging brake. Is that what you wanted to know?
      • 95shaw
        • Nov 2007
        • 205
        Adjust car to free entry. I've found needing to drag the brake helps compensate for too tight on entry.
        • Roudy73
          • Jun 2016
          • 33
          If the track slows an i let out of the gas without dragging the brake the car will just slide in the center?
          • King1
            • Jan 2012
            • 354
            Id say a little more roll steer would help. I cut my teeth on 1600's and I would drag the brake all the time but holding throttle and holding brake always kept the car tight for me. If it slicked off real bad I would go to front brake and and scrub the pedal to pull the nose down in the center.
