Rr spring rate when using soft rf
  • Dirtmod13
    • Jan 2014
    • 245
    Have had some success using a soft rf like the new rocket setup, but car is always too loose (but fast) Was wondering if by softening the rf, it needs a softer rr to compensate. I understand that roll couple theory would say after softening front and leaving the rear it would be looser.
    • 14324
    Short answer: No. You would be shocked the RR springs some guys are running. It is more of a momentum setup.
    • RCJ
      • Nov 2007
      • 509
      What r/r are some guys running?
      • 7uptruckracer
        • May 2009
        • 1336
        Would not hesitate with a 350 RR but its a package deal
          • 2020
          Why so soft? (grin)
          • 7uptruckracer
            • May 2009
            • 1336
            Also seen a dual stage that locks out to a 500
            Originally posted by billetbirdcage View Post
            Why so soft? (grin)
            • Matt49
              • 3123
              Excellent for hammer down track conditions. Free on entry, free on exit.
              • 7uptruckracer
                • May 2009
                • 1336
                I was told they used it to prevent mid corner squat...not sure why but I've seen things on the RR I haven't ever seen it's exciting and frustrating it seems to be a lot like BBSS on asphalt and just as sensitive lol
                • fastford
                  • 4059
                  any one seen a soft RR with a bump stop? I tkink it would work with with the proper shock , ie: soft comp and stiff rebound....
                    • 14324
                    I had a deal like that 3 years ago that worked very well at one particular track. 175# RR with a particular rollerskate wheel setup.
                    • 7uptruckracer
                      • May 2009
                      • 1336
                      I saw a Cone bump on a RR the other week that Shorty setup. Car couldn't get in the corner.....
                        • 14324
                        That can happen. LOL
                        • 7uptruckracer
                          • May 2009
                          • 1336
                          Yeah seemed to be getting on it way too late causing loss of side bite
                          • Dirtmod13
                            • Jan 2014
                            • 245
                            Assuming that's for qualifying right? Can't be good for small track that goes slick for the feature can it?
                            • 7uptruckracer
                              • May 2009
                              • 1336
                              Depends on the bump stop timing more RR spring can give you entry sidebite there are alot of variables. ALOT.
