Safety equipment and accident question involving Eldora fatality
  • Stede Bonnet
    • Sep 2016
    • 325
    I didn't want to post this in with the prayers and rip's as it would be distracting from the point of those posts. I'm in the process of designing building my own chassis because I just don't like the direction that modern DLM's have gone in regards to performance and most assuredly safety. So far I've incorporated a maximum allowed dropped deck with metal angled away from drivers right shoulder with a raised halo to enhance escapability. On top of halo I've welded in expanded metal covering the top to keep cage from sinking into track surface during roll over in case roof becomes detached and will not be using a Jbar at all. I also may use a double main hoop.
    The only pics I could find of Mr Unger's car show only a regular aluminum seat, head support on RS only, no full containment. I'm not a proponent of mandatory full containment because in most designs it significantly impairs escapability during a fire. However I am exploring some alternatives that address this.
    I wasn't in attendance so I don't know what happened, but I try to use every accident like this, whether it's fatal or handicapping as an opportunity to improve the design of my cars. So if someone feels comfortable enough to share what they saw happen, you don't have to be gory graphic, you can post here or PM me. I've heard he hit on the drivers side, but I don't know if another car t-boned him or if he hit the wall with the driver side.
    I've already heard some clamoring for mandatory Hans devices, but if he was injured from side impact as described, Hans offers little or no protection for that, only a full containment seat or properly installed window net or left side head rest would.
    Did the car ever turn over?
    Was the car T-boned on driver side?
    Did car hit wall drivers side first?
    What were the circumstances?
    I want only to use Mr Unger's sacrifice to save others and make safer race cars.
    Thank you for your help.
    Politically Incorrect.
  • Krooser
    • Nov 2012
    • 3117
    I HEARD he took a hard hit to the wall with the driver's side door area.
    Class of 2019
      • 2020
      Complete guess on my part but likely what happened from what little I know about the wreck:
      Head likely impacted the wall, from not having a containment seat or window net. This is what happened to Brian Harris several years ago, that he sustained a pretty good head injury.
      "The night of Harris’ crash, he was piloting the car without the state-of-the-art seat, and the left side of his helmeted head hit the roll bar when the car struck the wall." Says rollbar but I remember it being said he hit the wall with his head
      read full article here: https://frontporchexpressions.com/2010/04/13/898/
        • 2020
        Check out the 2 min mark
        • Stede Bonnet
          • Sep 2016
          • 325
          Thanks I checked out the article and the video, both were informative and helpful. Thank you. I'll probably end up branded the fool, but I just think the avenue that DLM setups have taken is too prone to flipping and therefore is inherently overly dangerous. I plan to pursue a different approach that doesnt involve j-bars. Our sport tends to be a "Monkey see, Monkey do" in its trends, instead of one of individual thought and creativity. Anyway thanks again and if you have any safety based ideas or designs you want to share feel free.
            Why is a panhard bent in a j shape more dangerous than a straight one?
            • Stede Bonnet
              • Sep 2016
              • 325
              "Necessity is the mother of invention."
              The shape isn't the issue, its the manner in which they are applied. A J-bar thru its, downward to the right angle and its natural arc of travel raises the rear of the car higher during cornering as well as the CG and the mass in the rear of the car. This angle of attack promotes excellent side bite, yes but puts the car in a vulnerable state, essentially positioning the car to vault over and flip if its bumped or runs thru a hole or rut wrong. A pan hard bar conversely is typically flat and doesn't promote as much mechanical side bite but also less likely to pop the car over. I realize with the modern setups on bumps and so forth, with the car positioned, "FDAU" works great for aero and side bite, but maybe there is a better way to generate side bite without risking so many racers ending up on their lids with concussions and trapped in burning cars. I understand the whole setup promotes the, "FDAU" attitude, but minus the J-bar it wouldn't be as easy to flip. People get so use to being Lemmings they forget how to think for themselves and/or lack the courage to venture outside the norm. What is it they say, "necessity is the mother of invention", well I think we need something different.
                Flat panhard bars work on pavement. I doubt it could ever work on dirt. And by "work" I mean be competitive. There simply is not enough grip to produce the weight transfer required to achieve the side bite required to get the car to stick in the corners. Not without REALLY slowing the car down...back to the "work" statement.
                Side bite is ALL about lateral weight transfer.
                I agree that we cannot pretend that safety issues don't exist but we also must acknowledge the laws of physics.
                J-bar or not, if you come up with a way to generate side bite equal to what a j-bar does, you're going to have the same problem (whether it is one is debatable) that you are describing. Meaning overloaded right side tires (again, debatable).
                This is assuming your intent isn't to put a sprint car wing on a late model.
                • Stede Bonnet
                  • Sep 2016
                  • 325
                  How the side bite is achieved is what wrong, not just having it or not. I say there is no debating the fact that cars flip way more than they use to, its a fact. It doesn't take a rocket scientist to know running around holding a block over your head is gonna tend to pull you over when direction is changed. I never said what I was gonna do was use a panhard bar or a bud-bar, I only compared it to the j-bar that Masters inquired about. Weight transfer happens whether the body moves or not, a go kart has weight transfer.... Thank you for your input.
                  • zeroracing
                    • 1014
                    Yes weight transfers no matter what, but there is a reason that formula type cars often remove anti-roll bars for wet (low grip) conditions...
                      I understand the concept of weight transfer. I raced karts for years. Not trying to turn this into an argument but you're trying to solve a problem that can't be solved. Weight transfer is what creates grip. You either want it or you don't.
                      • Stede Bonnet
                        • Sep 2016
                        • 325
                        You have to get outside the box...
                        As I stated earlier, it's the manner in which the weight transfer is achieved that is flawed.
                        "Trying to solve a problem that can not be solved", I love that. This is gonna be fun. Thank you all for your input.
                        Let me ask this question as food for thought, if "j-bars/left side strait bars" were banned tomorrow what would you do to regain your side bite? Think on that for a bit.
                          Okay...I'll play...
                          If j-bars/left side straight bars were banned, one would likely need to raise the VCG of the car in order to get side bite back. Or run less static left side weight. With either of these workarounds, we're back to the same problem that you tried to solve by banning the j-bar.
                          And finally I'll ask the best question of all...
                          What is your solution to achieving side bite equal to that of a j-bar that prevents a car from have a chance of rolling over?
                          • Lizardracing
                            • 839
                            Where are the references that today's dirt cars flip over more than ever? Who said it was from RS wheel loading? That sounds like a farce. Did someone make up a fact and then argue it's validity?
                              I don't think I saw a DLM flip, that wasn't because it ramped off the track surface and landed on a surface below track level, until after 2000. They get upside down fairly regularly now.
