TWO UPPER LEFT 4 BAR purpose?
  • rollijm
    • Jun 2016
    • 14
    What's the purpose to run two 4Bars on the the Left upper Birdcage? I've seen it done on GRT'S
  • RacerX10
    • 571
    Are you sure you aren't looking at one on the brake caliper and one on the birdcage ?
    • rollijm
      • Jun 2016
      • 14
      yes its on the brake caliper....
        That second bar is a brake floater. Instead of the caliper being attached to a bracket that is solid on the axle tube, it is attached to a "floater" which is kind of a like a birdcage but just for the caliper. It then has a bar that goes to the frame. With this setup, instead of LR braking force being transmitted to the 6th coil, it is transmitted to the chassis. It helps keep hike in the car on entry but can also make the car very free on entry. Adjustable on the frame and some brackets have adjustment on the floater itself.
        • rollijm
          • Jun 2016
          • 14
          awesome thank you
          • fastford
            • 4059
            i had very good luck with a left rear floater on a 350 rt frt spring, but when I started on the soft rt front set up, i found i didnt need it any more.
            • CCHIEF
              • Jul 2014
              • 399
              More commonly used on mods than lates.
              • Stede Bonnet
                • Sep 2016
                • 325
                Is it legal on lates anymore? I thought the "Rumley Rule" put the kabosh on any kind of smart stuff like that...
                Politically Incorrect.
