Originally posted by billetbirdcage
View Post
Winter updates
The strut location was in the wrong place on the V/C's, it was mounted to the main frame rail which is too far outboard compared to the lower control arm mount so it made the lower ball joint move backwards under compression and lost caster.Originally posted by fastford View Postdo you think they turned the strut back without correcting the cross member? i would think all that has to work together.
It's no different then mounting the upper arm not square with the frame, like many modified's are. Not being square makes the ball joint move front to back or vice versa on the car.Last edited by billetbirdcage; 10-11-2016, 07:29 PM.
The victory circle cars with the struts to the back were designed this way on purpose. The rear strut mount was outboard of the lower control arm mount. Think of a Chevelle clip, but not that much. He wanted the castor loss/ pro dive in roll. Lots of guys did not like it. The later front end was more popular, but it was more than the just the strut rods, it had taller spindles.
