I am a budget racer and have done lots of experimenting with chassis set ups etc. Obviously one of the main sources of traction and handling is shocks. What is everyones thoughts on the best shocks out now? The best shock builder and the best shock service as in technical support? What are the costs that everyone is paying on average for a set of shocks and/or revalving existing shocks? I am on a set of Integras right now and I havent a clue about shocks. I just send them off to have them "Built" and hang them on when they come back. Ive never gotten set up sheets or advice in tuning ever....What and who are you guys recommendations for shocks and builders that actually help their customers?
Conversation on Shocks
You need to look in your region who has cars up front, them go speak to those guys about they experience they have had with they shock builder. Some guys provide a TON of info on what to do with your shocks when you work with them and some builder send you nothing. Also need to find a person who is gonna be willing to help you thru the learning curve your going thru some guys have left a lot of newbies out to dry them gives the rest of the shock builders a bad name. If ya need anymore help with this feel free to give me a call Mike @ Warrior Race Cars/1G Shock Service 865.573.2411
Speaking strictly Mono-tube vs Mono-tube, brand to brand shouldn't make much difference if any at all. If the builder knows what he's doing he should be able to make one brand perform(dampening) the same as another. Just like in engines and matching the power curve to the car/conditions/driver, you match the dampening curve in the same way. Lets say for example you had a set of AFCO's that suit you and your car perfectly, a competent builder should be able to build you a set of Ohlins or Bilsteins or JRI's or Genesis or whatever's, that perform exactly the same for you. The only limiting factors from shock to shock to me would be oil quality and design limitations, such as one brand may have a wider adjustment potential built into its basic design. What ever brand you have already invested in should be fine, you just need a builder who knows his way around them to build them to suit you. Lots of good shocks being built today, I like Advanced(ARS) and Genesis.Originally posted by Cranky View PostI am a budget racer and have done lots of experimenting with chassis set ups etc. Obviously one of the main sources of traction and handling is shocks. What is everyones thoughts on the best shocks out now? The best shock builder and the best shock service as in technical support? What are the costs that everyone is paying on average for a set of shocks and/or revalving existing shocks? I am on a set of Integras right now and I havent a clue about shocks. I just send them off to have them "Built" and hang them on when they come back. Ive never gotten set up sheets or advice in tuning ever....What and who are you guys recommendations for shocks and builders that actually help their customers?
ARS - http://www.advancedracingsuspensions.com/
Genesis - http://www.genesisshocks.com/Last edited by Stede Bonnet; 10-06-2016, 03:45 PM.Politically Incorrect.
shocked
Originally posted by Stede Bonnet View PostSpeaking strictly Mono-tube vs Mono-tube, brand to brand shouldn't make much difference if any at all. If the builder knows what he's doing he should be able to make one brand perform(dampening) the same as another. Just like in engines and matching the power curve to the car/conditions/driver, you match the dampening curve in the same way. Lets say for example you had a set of AFCO's that suit you and your car perfectly, a competent builder should be able to build you a set of Ohlins or Bilsteins or JRI's or Genesis or whatever's, that perform exactly the same for you. The only limiting factors from shock to shock to me would be oil quality and design limitations, such as one brand may have a wider adjustment potential built into its basic design. What ever brand you have already invested in should be fine, you just need a builder who knows his way around them to build them to suit you. Lots of good shocks being built today, I like Advanced(ARS) and Genesis.
problem is you can have a say...Intergra, and build a Penske to the same dyno curves, and numbers, and it will not perform the same on the car.
I have seen it. (club 29)
you could have say a Bilstein shock, and have a Fox built to the same, and they are a dead up match on the dyno, and they do not work the same on the car.
I have lived that
granted an expert shock would need to know what to do to each of the shock company's piston stacks and bleed orifices, to make them comparable to one another (on the car feel). that takes a lot of R&D time , and a lot of someone's money..I think there should be lifeguards in the genepool.
The shock dyno only tells you so much about the shock performance. So, that is certainly very possible.Originally posted by JustAddDirt View Postproblem is you can have a say...Intergra, and build a Penske to the same dyno curves, and numbers, and it will not perform the same on the car.
I have lived that
The shaft changes direction very frequently on the race car. Your dyno sheet don't show what happens then.Last edited by MasterSbilt_Racer; 10-07-2016, 09:00 AM.Modern Day Spec Wedge Racing
Just like MBR said, there is a lot more to shocks than what the dyno can tell you. Sorry, Stede, but you are way off base on this one. Piston design, finish coatings, etc. have a huge impact on how a shock behaves on a race car and it can't be duplicated on any shock dyno that I know of. A shock dyno puts a shock through a constant velocity and changes direction at the same shaft displacement every time. The forces at work on a race car are usually trying to accelerate the shocks velocity, not maintain it. And they change their direction at a wide range of shaft displacements.
You need an electromechanical fatigue testing machine. Then you can do anything you want to the shock and measure response. I have access to servo-hydraulic, but they are too slow for a complete analysis.Originally posted by Matt49 View PostJust like MBR said, there is a lot more to shocks than what the dyno can tell you. Sorry, Stede, but you are way off base on this one. Piston design, finish coatings, etc. have a huge impact on how a shock behaves on a race car and it can't be duplicated on any shock dyno that I know of. A shock dyno puts a shock through a constant velocity and changes direction at the same shaft displacement every time. The forces at work on a race car are usually trying to accelerate the shocks velocity, not maintain it. And they change their direction at a wide range of shaft displacements.Modern Day Spec Wedge Racing
Off topic but I guess not really too far off, I've been wondering about his new Afco Technologies shocks.Originally posted by fastford View PostI became a huge jerry link fan several years back, helped me more than any one understand what shocks really do, especially when on a soft rt front set up, only problem now is since he went to afco, he is harder to contact......
Has anyone used them or heard anything on them? I can't imagine them not being pretty darn good.
it matters as to how sophisticated of dyno you use, I prefer Roerhig. Your right in that if you have a dyno that only gives, for example "peak values", you could build 2 shocks that look alike at peak velocity and not get the same performance on the track. There are dyno's that can measure everything you need them too though, its just a matter of $$$.Originally posted by JustAddDirt View Postproblem is you can have a say...Intergra, and build a Penske to the same dyno curves, and numbers, and it will not perform the same on the car.
I have lived that
granted an expert shock would need to know what to do to each of the shock company's piston stacks and bleed orifices, to make them comparable to one another (on the car feel). that takes a lot of R&D time , and a lot of someone's money..Last edited by Stede Bonnet; 10-13-2016, 10:15 AM.Politically Incorrect.
Stead
Are you a driver?
How long ago was that you built thousands of shocks?I think there should be lifeguards in the genepool.
