Oxengenated fuel vs lm plus
  • DEKconsulting
    • Apr 2015
    • 234
    Any difference in the two ?
    • 2020
    Yes, if you're talking like Q16 vs LM Plus, I see an average around 2% or so so on a 800HP engine your looking at 15 to 18HP.
    Are their down sides sure, so unless you really need that last bit of power I'd probably pass on it.
    • DEKconsulting
      • Apr 2015
      • 234
      We r running a crate so we would be running chp from vp or the 113 from vp the distributor is tellin me they r the same just barreled up different
      • CCHIEF
        • Jul 2014
        • 399
        Same fuels now, you have to jet larger for them vs non oxygenated fuels to actually get the power increase, your carb and intake will sweat like when running methanol. A return style fuel system is needed or the fuel will boil (vapor lock) due to the low vapor point. Must be stored correctly to retain it's quality. Good stuff just have to maintain your fuel system like a car on methanol. As a plus you can usually run about 34* timing on a 604 GM crate, and it will make more power only if you are tuned for it, most noticeable in hot humid weather and on restarts. ......Then their is CHP+
        • DEKconsulting
          • Apr 2015
          • 234
          What is the specific gravity of chp+
          • a25rjr
            • 3774
            See recent thread in Crate Late Model section. Good info from Brad Hibbard.
            Turn LEFT, Vote RIGHT!
              • 2020
              Specific Gravity: 0.740 at 60ºF
              • a25rjr
                • 3774
                What exactly does that mean?
                • DEKconsulting
                  • Apr 2015
                  • 234
                  So is 0.745 more or less our rule is 0.745 or less
                  • Lizardracing
                    • 839
                    Specific Gravity is how heavy is it compared to pure water. Water is considered 1.0 so .745 is heavier than .740.
                    Average pump gas somewhere around .720 to .780 depending on region and winter/summer blends.
                    • CCHIEF
                      • Jul 2014
                      • 399
                      Providing more power and versatility for the oval track racer, VP Racing Fuels introduces CHP+. Designed for naturally aspirated motors, CHP+ provides significant gains in both horsepower and torque. Check it out!
                      • a25rjr
                        • 3774
                        Very good! I was curious to what some would post. Being an owner in a chemical business for 30 plus years, I use that info every day.
                        If you want to know the weight of a product, just multiply the specific gravity times 8.33579(weight of pure water)
                        fyi......You can purchase a hydrometer for $10-25. Pour your fuel,or any other liquid, in a fairly tall container. Set the hydrometer in the fluid, and note the line level with the liquid. There are many lines with the specific gravity written on it (kinda like a thermometer). Just be sure to buy the one with the range of fluids to want to measure.
                        • sidewinder69
                          • Sep 2016
                          • 95
                          So is chp+ basically running alcohol?
                          • Brian Gray
                            • Feb 2012
                            • 1102
                            Vp crate is the same as vp113
                            Chp is more volatile, lower octane and the reid preasure I believe is higher to help it vaporize . Chp+ is slightly higher than Chp .
                            Depending on what your trying to accomplish chp was created to help gains on crates they found vp113 helped the engine run a little cooler and had some general gains so they repackaged it as crate so the consumer would be less put off by the numbers.
                            Shocks by BGR army
                            • Brian Gray
                              • Feb 2012
                              • 1102
                              Lm+ has some of the o2 components that vp113 has but has a better detonation character.
                              Lm+ is good fuel but you only need it if your past 15:1 . I've been using vp113 for the last 5 years in engines over 14:1. We opted though to cut it with lm+ on the big motor just to have some extra protection it didn't change the jetting at all so I'm thinking it's the same o2 as vp 113.
                              Shocks by BGR army
