Wet rough track
  • Tylerclem14
    • Oct 2016
    • 2
    Wet rough track
    I have a 2015 rocket and every time the track gets really wet and rough I'm always tight last time we moved both Right side bars up a hole and put a spring rubber in the RR. It only gets like that a few times a year but I want to figure it out. We have messed with everything but the springs. Thanks
  • TRocket8
    • 397
    Originally posted by grt74
    take the rubber OUT(your making the spring think its bigger,that will tighten entry),pick up the j bar on the pinion and or put a rr spacer on,more air pressure can help too,add rebound to the rr
    all of these can help but you'll have to see what works for you,you could also shorten the lr chain limiter too
    Wouldn't you want to take rebound out of the RR to help it turn in wet.
      Yes, you would. Helps the RR bar up coming off the corner.
      • CCHIEF
        • Jul 2014
        • 399
        .........PM Sent
        • RCJ
          • Nov 2007
          • 509
          Did the changes you made help?What part of the corner are you tight
            If this is Bubbas kid, he may be talking about Ocala. That place is way different from a normal joint. You are on the hammer into turn 3.
            • a25rjr
              • 3774
              Tyler, if that's you, Josh told us he usually runs 6" of stagger there. He also moved the jbar down on the frame 1".
              I would worry more about 1 and 2 since it is a momentum corner and you could lose a lot of speed if ur too tight there.
              Turn LEFT, Vote RIGHT!
