Oil cooler Poll
  • parocket
    • Feb 2010
    • 69
    Oil cooler Poll
    Ok a few easy questions:
    Do you run an oil cooler? yes or no
    If yes, where is it located
    What is your normal oil temp?
    Thanks for participating.
  • SLM98
    • Sep 2009
    • 407
    Yes I run a oil cooler. It is mounted on the deck of the car. Oil temp is 220-230. Anyone who doesn't run one is asking for trouble.
    • charlie#two
      • Dec 2007
      • 75
      New to the dry sump stuff . What brand cooler do most run? Single or double pass?
      • Brian Gray
        • Feb 2012
        • 1102
        Most people run an afco dual pass but if you really want to control the oil temp what we use cost significantly more money. But it will not effect flow rate , pressure ect.
        513-519-7745
        Shocks by BGR army
        • Brian Gray
          • Feb 2012
          • 1102
          But to answer I prefer single pass strab coolers mounted near the oil tankin rear.
          Shocks by BGR army
          • RCJ
            • Nov 2007
            • 509
            I'VE ran with and without one.There was not much change in oil temp.If I was racing 100 lap races,on a wet sump or raced 30 lap races on hammer down track every week I would run one.I do run a large oil tank, probably helps with cooling.
