We are having a small fuel pressure issue so checking all the possible items. Took the mechanical fuel pump off to check the fuel pump rod and it will not come out of the block and thinking the tip maybe worn down. I'm sure it's probably has a little burr on the end from running on the cam that is not letting it fall out very easily.
So my question is, what would be the easiest way to get to the tip to file down the edges a touch to let it slide out. It is a brass tip rod..
Can I get to it through the front throughthe Timing Cover ?
Can I get to it from the top side of the motor under the intake ?
Trying to remember if there are any holes that you can get to it without taking the motor a part and removing the cam?
Any ideas.....the is a pre 90's 4-bolt block...
