Is there a rule of thumb on where a all aluminum motor should be mounted? I have mine mounted high and to the right, does that sound right?
Aluminum Motor
That would be the normal location for an iron block, aluminum head installation.Modern Day Spec Wedge Racing
The old thinking was as I said because an iron block with aluminum heads has a low cg and the iron block may give you too much left side weight.
Like GRT74 said, most builders will now tell you to put it where the car scales out best and not worry about it. You won't likely be able to tell a difference with either mounting height. Put it left to right where the car scales easiest.Modern Day Spec Wedge Racing
