Are the Bert and Brinn couplers interchangeable? Thank you.
Question on Bert and Brinn couplers
The starter idler is the only part that has to match. Otherwise the belhousing are identical.
You can use either hub/flywheel as long as you have a matching starter idler gear.
As far as transmission goes yes both transmission will work on either drive hub.Shocks by BGR army
bell
a brinn bell will not work with a bert flywheel. a bert flywheel is smaller diameter and will take the teeth off i a couple of start ups.Originally posted by Brian Gray View PostThe starter idler is the only part that has to match. Otherwise the belhousing are identical.
This is correct,as the Brinn bell,is a copy of the Bert.Originally posted by Brian Gray View PostThe starter idler is the only part that has to match. Otherwise the belhousing are identical.
As far as transmission goes yes both transmission will work on either drive hub.you just got greased
http://www.goddardwarrior.net
