I want to try a LRF shock to help keep the car hiked. Gotta be non-adjustable oil shock. Can someone point me in the right direction for what I need to get?
LRF Shock
Am I correct in thinking that a LR traction shock with a high compression number would encourage the rear suspension to 'pogo stick' on a rough track? I have to think that you would lose traction with that rear end bouncing up and down...Last edited by Krooser; 12-27-2016, 12:11 AM.Member of the Luxemburg Speedway Hall of Fame
Class of 2019
Yes and no. When the bars are driving the chassis up in the lr corner, you have basically a rigid construction anyway. But yes, over damping is bad for traction.Originally posted by Krooser View PostAm I correct in thinking that a LR traction shock with a high compression number would encourage the rear suspension to 'pogo stick' on a rough track? I have to think that you would lose traction with that rear end bouncing up and down...Modern Day Spec Wedge Racing
Matt… I may have an AFCO shock that will work for you. I bought a box of shocks and all the Afco's are 5-0, 6-0 etc. They have the old style piston dsign but can be converted to shim stack technology… cheap to you!Member of the Luxemburg Speedway Hall of Fame
Class of 2019
