U joints for driveshaft.
  • hsracer
    • Feb 2011
    • 33
    Need to replace u joints on driveshaft. What's the best one to use. With grease fitting or no grease fitting.
  • dangerdann
    • Jun 2014
    • 79
    We always put non greaseable spicer in ours. They are stronger and are smoother due to thrust washers inside the caps.
    • Lizardracing
      • 839
      My DS guy always uses Spicer w/Zerks on the non thrust side to prevent breakage.
      • over4T
        • Feb 2015
        • 1108
        We've used both greasable and non and never had an issue with either but, like dangerdann and lizard said, always Spicer. U joints are not a place to save a buck or two.
        • DEKconsulting
          • Apr 2015
          • 234
          Spicer non great able here just make sure ur not over tightening ur u bolts
          • fastford
            • 4059
            one thing, spicer makes a standard and a heavy duty, the heavy duty has smaller needle bearings and are way stronger , this is what i use , as much movement as these drive lines have , they will hold up way longer.
            • CCHIEF
              • Jul 2014
              • 399
              Spicer, non greaseable +1 on the HD. Greaseable are hollow! Greaseable fine and preferred in a crate car. Replace every season for a weekly racer. Monitor the rear joint for any play at all, especially if running a lot of LR drop.
