What effects maybe experienced going from a twin tube to a mono tube w/100psi of nitrogen pressure? Both shocks are the same valving, but w/the added rod pressure of the mono tube, both shocks can't react the same, right?
LRF Shock ?
Thanks, that's what I was looking for. I figured it'd be similar to adding compression.Gill T. Azell
Entry was fine, needed to be a tad freer getting in anyhow, but had a killer throttle push! Went w/same bite as w/other, twin-tube LRF shock. (Setting bite w/shock off, btw)
Do I need to decrease the LR bite to remedy the throttle push with the new gas shock?Gill T. Azell
You need less wedge in the car at the point of throttle application. That is a snap-shot in time in dynamic situation. What is the car's attitude at that point? Is it on the lr spring? What is going on at the rf at that point?Modern Day Spec Wedge Racing
Car stayed up on bars all the way through the corners. Had the RF buried, so much that, we may now have a RF shock bottoming out causing the throttle push. I hate to stiffen the spring though. I like the idea of removing LR bite. Car looks like it just has too much LR drive in it!Originally posted by MasterSbilt_Racer View PostYou need less wedge in the car at the point of throttle application. That is a snap-shot in time in dynamic situation. What is the car's attitude at that point? Is it on the lr spring? What is going on at the rf at that point?Gill T. Azell
