Have 04 Rayburn with 10 updates came with pullrod installed does it require a spring on it any info would be helpful
04 Rayburn with 10 updates pull rod issue
The spring goes inside the pullbar body. Typically, you have a brake spring on the "lift bar."Modern Day Spec Wedge Racing
OK that makes sense is there any adjustments to it and do u unhook it to make adjustments to the car
Finally got time to take the pull bar off tonight took it apart no spring inside so guess now I'm needing to bye a spring for it and once I get the spring is there anything to adjust as far as preload
You scale the car with the pull bar disconnected, once scaled reattach bar and preload. I just can't remember how much, but I think its 1 turn or 1-1/2. The spring is whats called a punch press spring(dark green).Originally posted by Fireracer18 View PostFinally got time to take the pull bar off tonight took it apart no spring inside so guess now I'm needing to bye a spring for it and once I get the spring is there anything to adjust as far as preload
Mc MAster Carr #9595K17, 2 inch spring. $15.65 each
Politically Incorrect.
