Fuel system and pressures HELP!!!! Please !!
  • wismadman
    • 267
    I switched engine builders and was told to update. (private builder) Sold carb and bought new high volume fuel pump with a newer K&B carb. After like 10 nights and two engines I had to call it a season with no money to keep going.
    Started out with a 2nd but the air cleaner started on fire a little so I had to adjust some things. Everything I tried just got worse. Had a rebuilt CV pump on and it made too much pressure at a dead head. I tried a new regulator and by passed fuel back to the cell and was told to run like 7/8 pounds. To make a long story short.......I tried a different CV pump. I tried different regulators. Went back to a cheap holly/ carter low volume pump. bought new fuel lines. pulled fuel filter apart. Pulled (top feed) fuel cell apart. Sent the carb to K&B to look at and rebuild. Ran fuel in and out of carb and regulator every way you can to have nothing but problems.
    At first, engine would die trying to put heat in tired. Fell on face. Floats too high ? Then the car wouldn't start without 3/4 throttle wouldn't idle. Than after getting heat and get in line up it would quit. a mother to get started and wouldn't run unless it's at 3000 rpm. fuel pressure would drop as it got hot. dripping fuel out the top of carb. Tried turning fuel floats down. I mean the whole season/ all 10 nights was fighting fighting and more fighting fuel problems. The only thing I couldn't do was put old carbs on that I sold and I was broke. (Blake and Braswell)
    So if anyone can help me with the newest and greatest with these cars rolling over on the right front and messing with the carb or not would be greatly appreciative. I some how cracked one block behind a cylinder and pushed water pass the cap and burnt a hole in a piston pushing (not a nice word)(not a nice word)(not a nice word)(not a nice word) loads of oil out the rear main on #2. Both engines are alum dart blocks and 18 degree heads. I'm running vp 114 racing fuel. Been at this for 16yrs and I've never been so frustrated!!!!
  • rakracing
    • Dec 2014
    • 218
    sounds more like a vacuum leak more than anything, it wont idle, and leans out and burns pistons check the intake good and check the intake gasket maybe the intake and head aint matching, dry or wet sump
    • keeks
      • Oct 2008
      • 687
      Gas or Alky?
      • Kromulous
        • 3008
        Gas or alky, yes?
        KSE belt drive or off the back of the dry sump pump.
        I would never on purpose run any sort of mech pump, ever, ever x 10, & ever again.
        Just say no...
          • 2019
          there is your answer
          • petesbuyin
            • 56
            So you're a rookie at this then? Just kidding. I have been at this just about triple that amount and it still frustrates me some times. The very first thing i would look at is that you have the correct gasket between the base plate and the main body. If you have the wrong gasket it will block off the idle passages which will make the engine very difficult to start and near impossible to run under 3000 rpm. If you can get the motor to run enough to get it on the track it will run real lean and want to die every time you let off to enter the corner. I have seen very talented carb builders just grab the wrong gasket and make this mistake.
            A droop rule is like infield tractor tires, everyone knows it's stupid, but they still keep doing it.
            • dirtrace09
              • Aug 2007
              • 746
              I would start at the fuel cell and check every single connection all the way to the carb. I have seen a system pull air from fittings that people swear are good, tight, etc... Air leaks act this way.
              • wismadman
                • 267
                The die thing comes and goes. throwing the car back in forth to get heat the engine would die till the car leveled out. What am I looking for in this gasket? My engine builder took it apart twice and so did the carb person. just don't get why the fuel pressure goes down as it gets hot. electric gauge and mechanical .
                I took the whole fuel system apart. It's like the carb or something.
                • Brian Gray
                  • Feb 2012
                  • 1102
                  Get an Afr gauge.
                  Shocks by BGR army
                  • keeks
                    • Oct 2008
                    • 687
                    If you have jet extensions on it, make sure the float isn't hanging up on them.
                    • 50j
                      • 1047
                      I have seen this several times too. It can be fittings not threaded in far enough, bad lines, even a crack in the pick-up tube or the tube floating to the top. If pressure changes when it gets hot, it's probably sucking in air or boiling the fuel if lines are close to headers or a radiator hose. Putting a known to be good borrowed carb on for a night wouldn't be a terrible idea either. If you use a different carb, make sure it suits your engine and fuel. Your engine builder may have one, or possibly another racer with a very similar engine and the same fuel.
                      • pfd60
                        • Aug 2012
                        • 161
                        Make sure you have a -10 going back to cell and a working bypass. I had the same type of pressure differences. It took me four nights to figure it out. The bypass was my problem.
                        • wismadman
                          • 267
                          I didn't look at the alum tube in the cell. I don't know the route with the high volume pump. When does the regulator go into the system. What regulator? 2 or 3 port? size of line? pressure at idle pressure at 3,000? thanks again. Going to try to buy new msd and coils to take out that problem.
                          • Lizardracing
                            • 839
                            Electrical Problems are the easiest things to fix and don't usually cost much if anything. Some ideas are....Plates in the battery loose or broken, I've seen ignition switches fail with broken poles on the inside, Zip ties cutting through the wires, loose or corroded terminals. I hate the crimp on stuff. I always solder and heat shrink everything. I'd pull every connection and sand both sides of the connections. At the very least your eliminating any future problems that seems to creep up at the track and not at home in the shop.
                            Like above, I'd check every fuel line connection including the cell pick up tube in the cell and the roll over vent. I'd change the filter and the pump push rod. I'd check the pump push rod travel too in case the cam lobe went flat. I'd look for broken valves or trash in the valves in the pump. I'd replace the needles and seat with Holley brands only. The float drop is very important and often overlooked. Replace the Power valves and blow out every office and holes and tube in the carb paying much attention to the idle air bleeds and restrictions. Take you sweet ass time and work alone without distractions and I think your bound to find your problem even if you don't find anything obvious sometimes cleaning up all the little details takes car of it.
                            • ALF401
                              • 164
                              We ruined an engine once and finally found out the pickup tube in the fuel cell (fuel pick line ran out the top) had a small crack in the fuel hose at the inside top of the fuel cell. Gas in the carb like you described the whole time!! When we put a new engine in, we ran the fuel line from a fuel jug by the right front tire and it run great. Put the regular fuel line from the fuel cell and old problems started again.
