Gear oil?
  • Crash101
    • Jul 2016
    • 23
    Gear oil?
    What gear oil do you guys recommend? Do I need 50 dollar a gallon oil or can I just go cheaper and change more often? I'm not at trying to be cheap, just curious what different stuff guys are using.
  • Krooser
    • Nov 2012
    • 3117
    Synthetic works best but you can get good results with a dino 80w90, too.
    Class of 2019
    • RCJ
      • Nov 2007
      • 509
      Q/C aren't as sensitive to gear oil as the 9'' fords.Any good quality oil will give good life.One thing that I found with the low cost oils (house brand type) is, they will give up or break down quicker and need to be changed more often.
      • JustAddDirt
        • 1893
        I run Lucas oil synthetic 80/90
        Had great luck with it over th years.
        • SS Motorsports
          • Sep 2008
          • 431
          Mystik is pretty good stuff, can't remember what it runs anymore though
          • LM14
            • 490
            We ran Valvoline Synthetic. Found our gears were much cooler when changing them between hot laps/heat/feature. Never had a failure with it in a QC or a 9".
            SPark
            • hall99
              • 421
              weve run schaeffer's for a long time
              • Brian Gray
                • Feb 2012
                • 1102
                I'm on the valvoline synth wagon too. But we always have added a full small tube of graphite moly powder to it.
                Great wear and smooth operation.
                Shocks by BGR army
