Water distilled? Spring?Anti freeze or not? Additives?
What fluid you run in radiator?
Coulda fooled me. I run antifreeze every weekend. I've never seen rules against it. Lubrication in it alone is worth it in my opinion. But I do add water wetter as well.
Punisher, please do not run antifreeze for you and your competitors sake. It is illegal at alot of places. If you were ever to loose a hose entering the corner on a hard track it is bad enough for you and the competitors behind you when running only water for obvious reasons. Antifreeze makes the impact even worse because it is very slick! Have seen this happen. They say to run distilled water and water wetter to avoid corroding the radiator, but I run tap water with a little wetter for the water pump. Maybe the radiator will corrode faster with tap water, but how long do you truthfully keep a radiator these days? Good luck!
ive never herd of antifreeze being illegal any where around here , i go to a few winter races , such as the ice bowl and you better have some in it, was told of 3 or 4 engines that froze on the first friday night this year. all i use the rest of the time is distilled water , tap water containing chlorine will damage a new radiator because of corrosion. they say if you set an open container of tap water out for several hours , 5 i think, the chlorine will disappear , but distilled water is so cheap, i just buy it.
I use anti freeze ,but I'm not mixing it 50/50.some where between a quart and 1/2 gallon.Everybody will tell you that anti freeze doesn't conduct heat as good as water and that is true ,but it raises the boiling point.I've had cars that would run a little cooler with some anti freeze in them.I feel like the increase in boiling point let in cool around the exhaust ports better.
My preference is 1/2 gallon antifreeze 1 bottle of water wetter and the rest is plain water. #1 reason to use antifreeze and ww. Next time you're near a hot stovepipe throw a little water on it and watch it jump off. A little antifreeze helps keep the water from doing that around the exhaust ports during racing. But yes it's illegal at every asphalt track I've been to but I have never heard about it on the dirt.Shocks by BGR army
Talked to the guys at Griffin Radiators a couple of years ago and they flat told me not to use tap water and that they had radiators brought in that used tap stuff and, with only a couple of races on them, were already clogged and corroded. Tap water around the country is very inconsistent...think Flint, Michigan. Yuck!!
VPs stay frosty.... I used to run straight water with a couple of the pellets for corrosion resistance, but switched this past summer. It is the only "coolant" that actually does what is advertised...(dropped temps 10-15 degrees with nothing else changed). It also has a corrosion inhibitor in it so nothing needs to be added.
Each owner of an iron horse has his own position regarding car maintenance. Nevertheless, if the question is about which is better, then every man will advise the liquid that he pours into his car. I want to tell you that it is better to find out for yourself which Antifreeze for Aluminum Radiator will suit your opinion for your car.Last edited by CharlieR; 11-05-2021, 02:57 AM.
