wonder if anyone happened to know what the measurements for where the birdcages go on a smackdown 34l 35r axles also what bolt holts do I us top or bottom, which mounting hole for shock brackets
masterbilt rearend measurements
pm Matt49. Pretty sure he has that.Originally posted by mmarineservice View Postwonder if anyone happened to know what the measurements for where the birdcages go on a smackdown 34l 35r axles also what bolt holts do I us top or bottom, which mounting hole for shock bracketsTurn LEFT, Vote RIGHT!
When the gen x first came out you couldn't buy a bare frame. This was because quite a few things were different. Rear included. I never had those axles until I had a gen x.Originally posted by collateralDamage View Posti heard 34/35 axle tubes are for GenX so that can't be right...Modern Day Spec Wedge Racing
The gen x, with that rear has the RR shock mount 7.5" from inside of RR rotor. 7 7/8 on lrModern Day Spec Wedge Racing
Smack 34/35 is 8.5" from OUTSIDE of brake rotor on the RR, 9.125" on the LR. Using the outside of the brake rotor eliminates the difference in thickness between a standard .810" and 1.25" rotor.
33/35 was standard on smack and 34/35 is standard on Gen-X. On the Gen-X, the numbers I've used are 7-1/4" from RR shock mount center to inside of brake rotor and 7-7/8" from center of LR shock mount to inside of brake rotor.
I do not have or recall the numbers on a smack car but I do know a lot of folks run 34/35 on a smack.
I think you moved in the RR rail right? I would remove the RR axle and cut off 1 inch if so. Depends on how you center the rear, but in general, tighter exit and looser entry.Modern Day Spec Wedge Racing
MBR... Good memory!
I can get on the latest 'hot set-up' bandwagon too if I do that. Right now I have a steel tube on the right side and aluminum on the left. I can cut and switch the steel tube to the left side then buy a shorter right aluminum tube. That, and a another 300 HP, will put me into the whiners (I mean winner's) circle in no time!
Now to find some heavy duty Peterbilt muffler clamps for the 100 lbs. of Mallory metal I'l bolt on the left tube... gotta check YouTube for ideas...Member of the Luxemburg Speedway Hall of Fame
Class of 2019
