I would look more toward ackermann or dynamic toe changes as you turn the wheel.
After screwing around with this ove thw past several years, I think this is one of the most underated adjustment you can make to a front end.
I've seen as much as two and half inches of toe out in some of these front ends in both left turn and right turn.
Think about putting two and a half inches of static toe in your car and how much a snow plow it would be.
I think one of the best investments a racer can make right now is one of Sweets ackermann guages.
Put ride height bars in your car and find out what kind of toe you are getting in left and right turn.
then start adjusting the steering arm on the spindle to reduce it down.
Getting counter steer ackermann to near zero will help your car launch off the corner.
Good Luck,
Kevin
Good Luck,
Kevin
