Priming dry sump issues
  • BNaylor91s
    • Oct 2016
    • 23
    We are trying to prime our dry Sump. We cannot get oil pressure and have smoked 2 drills. When we run the drill and stop, the pump starts to spin the opposite direction. We pulled on the belt by hand and it gets so hard to turn the pump the belt starts slipping. Any ideas what is going on?
    Sounds like you are dead heading the pump somehow. Trying to push oil into a place where it can't flow and don't belong.
    • Brian Gray
      • Feb 2012
      • 1102
      Your plumbing is most likely wrong. What block do you have?
      Shocks by BGR army
      • BNaylor91s
        • Oct 2016
        • 23
        Figured it out, had helped hook up the lines to the filter. Had the in/out reversed, thanks guys
        • racer2e
          • Jan 2012
          • 54
          I would replace that filter just in case the high pressure in the reverse direction damaged or collapsed it.
          • BNaylor91s
            • Oct 2016
            • 23
            I'll do that for sure, thanks man
