I just took a car in on trade and it has a Bulldog Dmi rearend.. the guy said he thinks it a 4.11 but wasn't 100% is they a way I can find out by looking or will it have to be an experiment type deal with gears at the track?
Rearend Ratio
Should be a tag on the top of the center section with a serial number. If so, I'm sure you could call them and they'll tell you. Otherwise, if it's together (got axles/hubs), put a set of known gears (ratio) in and and just turn the pinion by hand until the hub makes one full turn. It should get you close as there's a pretty good difference between final ratios of the same gear set in a 4.11 versus a 4.86. I certainly wouldn't go to the track without knowing what's in it first.
I agree...know before you go or you'll either be gear bound or blow up a motor.
What Jet described will work but you can do it without any QC gears in it too. Take the QC cover off and make a mark on your upper shaft. Rotate the hubs 360* and count the rotations of the shaft. If it's a little more than 4, 4.11 it is. A little less than 5, 4.86 it is.
Just take the Q/C gears out and turn the upper shaft which is the pinion and count how many turns to turn the axle/hub one turn. Either gonna be slightly over a turn for a 4.11 or real close to 5 turns for a 4.86Originally posted by racert22 View PostI just took a car in on trade and it has a Bulldog Dmi rearend.. the guy said he thinks it a 4.11 but wasn't 100% is they a way I can find out by looking or will it have to be an experiment type deal with gears at the track?
Should be. If you want to be really sure, give the hub 3 full turns. A 4.86 will get you to right at 14.5 and 4.11 will get you to just under 12.5. Harder mess up if you check it this way.Originally posted by racert22 View PostI took the gears out and turned the hub/pinion a full turn. It turned about 4 & 3/4s of a turn. So will that be a 4.86?
