What do you guys think of this?
Digressive Springs
A preloader does not create a stiffer rate at any point . it allows you to compress a softer rate spring or any for that matter and then lower you ride height lower than it would sit without the loader while still acheiving a given load at a particular travel point. It also generally has the opposite effect of a soft spring on exit at least when used on the rrOriginally posted by MachineMasters View PostLook into a spring preloader cartridge. This allows you to preload a softer rate spring (usually on the RR) to have a stiff rate for entry and a soft rate for exit.jury is still out on these in my opinion..
Now if it was part of a dual rate system...Originally posted by Jking24 View PostA preloader does not create a stiffer rate at any point . it allows you to compress a softer rate spring or any for that matter and then lower you ride height lower than it would sit without the loader while still acheiving a given load at a particular travel point. It also generally has the opposite effect of a soft spring on exit at least when used on the rrModern Day Spec Wedge Racing
This digressive stack setup for the 5th coil by advanced has been around for some time now, your first inch of travel is the stiffest.
facebook.com/mcjrmedia
