Raced Saturday and after the track cleaned up a bit I moved to the high side, last 5 laps the car would want to turn sharp right at the end of the straight. Assuming it's climbing the bars on the right side and the rear steer to the right is the culprit. Any ideas?
Weird sharp right turn at end of straight
Is it turning right when you dump the gas and everything unloads ? My old car did that .. scary as hell. It turned out that I didn't have enough damping on the unload and I'm pretty sure that I was getting rear steer the wrong way at the end of the suspension dump.
Adding a bunch of LR front shock fixed it for me, slowed down the unload and kept the front end pointed in the right direction. Don't know if that's what's happening to you, but there ya go.
Good luck.
Make yourself a limiter for the RR, I typically run about .25-.5" of gap from the spring to the adjuster nut (when the rear is hanging). Mine doesn't do that funky right turn anymore...Here's my little home on Youtube!
Home Page
http://www.AmickRacing.com
It is probably the LR shock compression being too soft. It is letting it fall and causing the rear steer to come out of it all at once, causing it to turn right. Check for mechanical and brake issues also. 90% of the time, it is LR shock.
