Standard damper vs. Fluid Damper
  • Krooser
    • Nov 2012
    • 3117
    i have a fluid damper that I got with my project engine... some guys like 'em but many don't. Seems like the standard deal is favored... your opinions based on first hand experience?
    Thanks...
    Class of 2019
    • 2020
    Thanks...
    Fluid damper is better for steady state RPM, but lacks in rapid sweeping RPM thus why they aren't overly thought of for circle track. However with that said, I wouldn't be afraid to run one as I had several I ran for years with factory cast cranks turning over 8000 RPM and never had an issue. However I didn't run the cranks that long about 2 seasons and where always zyglo tested between years to check for cracks.
    Since your on a budget and if you already have it, I'd use it without worries. If you have to buy I'd go with an ATI.
    • Krooser
      • Nov 2012
      • 3117
      Thanks BBC... this deal has about 30 nights on it. Should be ok to use but I value others opinions on this kinda stuff. Some wouldn't use one on a Briggs and Scrap Iron and others swear by them... you know how that goes...
      Class of 2019
