Limited Late HP
  • rickybobby23
    • Sep 2012
    • 30
    Limited Late HP
    I can buy an all steel wet sump motor for very reasonable price to try to move up a class, but dyno sheet says around 450 hp. I know this is quite lower than most regular limited Late engines, but I wondered if it would be worth the buy just to get used to things, or if getting something more competitive would be best money spent. I don't want to be 3/4 of a lap down after 20 laps just because I'm that low on hp. I usually run a 1/2 or 5/8 mile track. Any suggestions are appreciated.
  • Basecircle
    • Dec 2016
    • 82
    What are the engine rules where you run? I've seen limited late rules vary quite a bit depending where you race.
      If you run small slick tracks you should be fine. Hell, I once set fast time at a local super show with a stock block, flat top piston, 23 degree head engine.
      • fastlane99
        • May 2012
        • 47
        Most of the tracks that I would possibly run on are 1/2 or 5/8 mile. Their rules are pretty similar. 358 or 360 ci max. World products or factory gm heads. Flat tappet cams, flat top pistons. Wet or dry dump.
        • rickybobby23
          • Sep 2012
          • 30
          Ricky Bobby, your rules sound similar to mine. Although I believe tracks around me will allow Chevy bow tie heads and block. Not allowed anything titanium.
          • fastford
            • 4059
            i have seen engines with less power than that win races, if its a good deal and quality stuff, it would be fine to start with, then you could upgrade (add power) as you go...
            • a25rjr
              • 3774
              If you cant run the Chevy bowtie heads, you'll be in the ballpark. Between those and angle milling them is the main difference.
              Turn LEFT, Vote RIGHT!
