Leaking bert trans
  • Younggun32
    • Jan 2014
    • 28
    Leaking bert trans
    My bert is leaking towards the front and coming out of the bell housing. I took it out and put a new front seal in and re-sealed everything and put it back in and it still leaking after that. Where could it be coming from? I dont see anything obvious.
  • Racermb
    • Aug 2016
    • 14
    It's leaking where the lower shaft goes in the case
    • z40chief
      • 90
      There is a o-ring on the lower shaft that goes thru the case and clutch assembly. Look at a picture of a bert disassembled and you will see it.
      • rakracing
        • Dec 2014
        • 218
        mine always leaked when removed and reinstalled, dig out the old silicone, clean with 2+2, over fill area with new silicone and install while wet, all better tomorrow .
