Just got the car out for the year. In the pits if you steer slowly back and forth everything is normal, if you go to lock the back the other way the steering wheel and front tires chatter or shake as you turn, if you quickly jerk the wheel left then right it does the same on the counter steer. On the track the car is darty, and jerks right of you dump the gas, much harder than any car I have ever drove. I am suspecting the servo is having issues, anybody else have similar experiences or advice?
Checked and rechecked caster, toe, turned up LR compression for the right turn issue, still there.
