I use the hole saw type notcher, just wandering what the best, longest lasting saw blade is best to use, also i was thinking of rigging up some type of water soluble fluid cooling system and just wandering if any one else has done this, thanks.
tubing notcher
Just like any machine tooling. It's all about feeds and speeds. The right RPM, the right feed rate, a little cutting fluid and tools last a good long while.
I bought a full set of Lennox years ago and they still work well. I also use Rapid Tap for a cutting fluid and watch the feed and speed so they cut without burning the saw teeth. You want the heat in the chip not the tool.
thanks guys, i have an old drill press i dont use any more and im mounting my notcher on it , it has a table that is made for cooling fluid so i was thinking about getting me a small pump and using water soluble oil like in my big band saw . i have tried the snips before and i can do it, but im getting a little age on me and think i will stick with the notcher.
