Fan ?
  • Pete
    • Nov 2010
    • 55
    Fan ?
    Does anyone know what fan blade most top dirt teams or what top engine buidlers recommend to use? Part numbers appreciated. Thanks for any info.
  • JustAddDirt
    • 1893
    GM# 405442
    19" 4 blade fan
    • collateralDamage
      • Jul 2010
      • 110
      High Performance Race Fans.
      • Basecircle
        • Dec 2016
        • 82
        Definitely the gm fan listed above. If that doesn't keep it cool, you have other serious issues with your cooling system/combination. As extra insurance, change it after a while. I've seen them break a few times. Remember, it was a factory fan on an engine that probably never saw 5k rpm. Never had a "racing" fan that could cool like it does though.
        • Wizard 05
          • Jul 2016
          • 28
          Keyser Manufacturing part #100-15365 $49.95
          • MBR Performance
            • Nov 2014
            • 199
            The Keyser one is a cheap knockoff. The angle of the blade is formed differently and will flatten out over time and lose angle. Spend the money and buy the right part.
            • A ron
              • Apr 2014
              • 294
              I was having over heating problems. Added changed to the 19" Gm fan and removed the shroud and went from 230-240 after a few laps to no having trouble getting the water temp to 180 now.
              • Krooser
                • Nov 2012
                • 3117
                Check out the Engine Masters fan video on YouTube....
                Class of 2019
                • Pete
                  • Nov 2010
                  • 55
                  Is an Ac-Delco 405442 the same fan?
                  • perfconn
                    • 3636
                    AC-Delco is GM
                    • Brian Gray
                      • Feb 2012
                      • 1102
                      I have never had any issues with cooling using a 15" 6 blade and a shroud. Even on very big inch engines. You might need to rethink your cooling routing and water speed. More so than the fan.
                      Shocks by BGR army
                      • JustAddDirt
                        • 1893
                        fan
                        there is an AC Delco part number for that FAN:
                        15-80752
                        same fan, even has 405442 stamped on the blades
                        • GPSracer
                          • Oct 2018
                          • 2
                          Contact any of the larger chassis manufacturers to get your GPS Max Air 17" 6 blade fan. They have them in stock or go to GorsuchPerformanceSolutions.com. This fan is being used by the majority of professional teams and has had great success in both woodlms and lodlms. Even the local guys like them and they have been run on crates and finished 1st and 2nd in the Dirt Late model Wissota Challenge Series this year.
                          • Kromulous
                            • 3008
                            One thing to keep in mind about the Race Fan is you can run 3 Blades, if you don't have cooling Issues.
                            Now days its not really a question about cooling system, most everyone has the same stuff. I noticed the heat creeps up when i get the nose to sealed off, especially when on a softer LF spring.
                            Just say no...
                            • powerslide
                              • 2696
                              bumped a post from 2017 to pedal his junk nice two first posts
