Mastersbilt
  • MBR Performance
    • Nov 2014
    • 199
    Mastersbilt
    Had anyone heard anything on the new car that's being designed? How much is being changed other than basic design ie. Front geometry, rear geometry, ect. Also when they may get it out on the track? Thanks in advance.
    I've seen one on the jig and it is unrecognizable compared to anything out of that shop in the last 20 years. Several safety improvements in terms of making the tub area bigger in all directions and the cage is braced better. Completely different front end and entire right side lower frame rail is raised considerably.
    Last I was there about 3 weeks ago they said they just hadn't had any time to test yet. They've got a roller sitting there ready to go.
    • MBR Performance
      • Nov 2014
      • 199
      Thank you for the info
      • Car18
        • 5
        What car are you talking about the GenX+ car made from the docol
          We're not talking about a GenX car at all. This is a completely new/different design.
          • MBR Performance
            • Nov 2014
            • 199
            One thing I like about Mastersbilt is they won't put out a new car without proper testing unlike some others (rocket). Hopefully some parts will transfer over from the GenX platform.
            • dkibel
              • Sep 2015
              • 28
              I heard that all the parts will transfer from a GenX car onto the new car. Sounds pretty good. It will be interesting to see how it performs.
                Keith told me that the front end would be completely different in terms of control arms and spindles.
                • MBR Performance
                  • Nov 2014
                  • 199
                  I seen pics of a 2018 Mastersbilt on Poncho's Facebook and it looks the same as a 2017.
                  • TheJet-09
                    • Jul 2013
                    • 1616
                    Is this what you are referring to?
                    The "MBH" sticks out to me first, and I have no idea what the major differences were between those and a chassis straight from Mastersbilt. I can say the battery is in a different location (at least as compared to my Gen-X), the front is "X'd" in front of the shaker screen (go figure), there are bolt in underslung bars, and a "bay bar" has been added up in front of the existing left hand door bar that wraps around in front of the pedals. Maybe the mounting points have changed some, or maybe this is just a 2018 version of what MBH was already doing.
                    • collateralDamage
                      • Jul 2010
                      • 110
                      that is definitely not the 2018/new car.
                      the new design isn't incredibly different but is noticeable even in full body.
                      • MLR19
                        • 475
                        The new car has the X in front of shaker screen,brace added to left front upper shock mount, the rear rails have been raised up , & the rear hoop has been changed to make the drivers compartment bigger, along with extra bracing in the drivers compartment Rack & strut have been raised, as well as the right side frame rail .Battery has been moved to allow dropped deck ,mostly all Docol tubing.
                        Also has welded in under rail on R.S. and bolt in on left.
                        The 2017 car we raced this year has most of those changes with the exception of the raised rear rails, and cage changes, it works much better that the 2015 car we have.
                        Unless something has changed since I last talked to Keith, all front end parts from a gen-x should be the same.
                        • MBR Performance
                          • Nov 2014
                          • 199
                          Thanks for the info guys. I wasn't sure if they changed anything on the front like spindles or mounting points. If anybody gets some pics please let me know.
                          • CCHIEF
                            • Jul 2014
                            • 399
                            One thing I like about Mastersbilt is they won't put out a new car without proper testing unlike some others (rocket). Hopefully some parts will transfer over from the GenX platform. MBR Performance Engineering www.mbrperformance.tk/
                            Kinda like your link to nowhere? What Rocket are you referring to, the XR1?
                            • MBR Performance
                              • Nov 2014
                              • 199
                              The orange front debacle. I didn't keep up with my web page.
