I kind of agree with CCHIEF here. A 5th coil change isn't going to take you from junk in the slick (what you're describing) to running up front. Go back to standard 5th coil rate and location and figure out why you're not getting any body roll. Something could be in a slight bind that tractioned up conditions is overcoming. Body roll starts with side bite and then you can really start to hike the LR and get forward bite.
Check both right side shock travel indicators after a run in the slick and this can tell you a lot about where you're lacking side bite.
Where are your j-bar heights at each end?
