Picked up a Rayburn 4 bar has grt 4 bar brackets has purple spindles have some questions what size rack does it take has aluminum birdcages from a grt need bar lengths generally a set up to try ride heights springs etc has lr shock behind mount can be ran z on right rear also what lift bar should I use and what length of j bar and how high on frame should it go also what size spacer should I use on rf upper a arm
08 Rayburn 4 bar
18.25" rack. Kinda hard to know other stuff cause it depends on how the person who Frankensteined it intended for it to be.Originally posted by Fireracer18 View PostPicked up a Rayburn 4 bar has grt 4 bar brackets has purple spindles have some questions what size rack does it take has aluminum birdcages from a grt need bar lengths generally a set up to try ride heights springs etc has lr shock behind mount can be ran z on right rear also what lift bar should I use and what length of j bar and how high on frame should it go also what size spacer should I use on rf upper a armModern Day Spec Wedge Racing
