Help getting car to rotate
  • BSW75
    • Mar 2017
    • 10
    On smaller tracks we struggle getting our car to rotate. We move the lr bottom bar up and it rotates well. But then when it gets slick it has no drive. But if we lower the lr back down I have trouble rotating. Other options?
    It all depends on how the car is being driven. Stagger, spring changes (less lf spring) could be in the cards.
      Try leaving your bottom left up one hole but then when it gets slick, move your top left up one hole on the frame. This will give you some drive without sacrificing rear steer. You could also lower the top left bar one hole on the birdcage.
      • BSW75
        • Mar 2017
        • 10
        Thank you very much
