Progressive vs stack
  • Aggressor
    • Dec 2009
    • 62
    Is the 175-350 progressive spring same as running a 175-350 stack?
    • 14303
    No. You can't adjust when a spring changes rate. And the transition from soft to stiff rate will look different as well.
    • Basecircle
      • Dec 2016
      • 82
      If you stack them, without a lockout, it will just act like a non-progressive approx. 117lb spring. If you run a lockout, it will be a 117 until it hits the lock, then switch instantly to a 350. A progressive is just that.... progressive.
