Looking at an engine to buy. Rules state 11-1 max compression. It's an all steel 355, flat top pistons level with deck, .015 head gasket, 49cc dart platinums untouched. Knowing this can compression ratio be figured? Thank You
Engine guys. Need help.
Do you know the volume of the valve reliefs in the pistons? You'll be able to figure it out pretty close with that info, but still not exact. There are a lot of variables if you need to be exact.
Found some info on the pistons. It says 10.4-1 with 64cc chamber, 10.7-1 with 58cc chamber. Heads are 49cc
Do you need to be legal or just pass the pump test, big difference? LOL.
There are several ways to beat the pump test but depends on how smart your tech guy is to which one will work.
4.03 x 3.48 with -6 cc valve relief, 49cc head and .015 gasket (I used a 4.200 diameter on the gasket but for a steel shim I think that is large as I don't remember the diameter now) and zero deck is around 13.33 to 1
Forget that MY BAD, was thinking beating the CID pump not a whistler to check compression.Last edited by billetbirdcage; 09-06-2017, 06:47 PM.
Try your computation with the actual volume of the head gasket, most are not round! The exact # for valve relief for pistons, add gasket volume to that, and add 1.5cc for ring land back volume. The online calculators don't allow for some of the variables (gasket and space from piston top to rings. Then you will have some ring and valve leakage after your computed #. You may pass a whistler, or you need a thicker gasket if they truly are 0.015". Agree that at 0.015" and zero deck, you'd be running over your rods right quick! What piston # does it have? What gasket #?Last edited by CCHIEF; 09-07-2017, 05:06 PM.
https://www.google.com/search?q=quen...utf-8&oe=utf-8 , you'll find why deck clearance and gasket thickness are very important for making power and avoiding detonation
