gears 4 gateway
  • brewster baker
    • 30
    gears 4 gateway
    gears 4 late model and modified at gateway dirt
  • Punisher88
    • Nov 2014
    • 495
    I was on a 7.12 with a 358 flat tappet nlms motor with spec brodix aluminum 23* heads. Turned 85-8700.
    • dirtracerl77
      • 89
      I ran a 6.86 in a mod. I had a good full roller 355, turned it 8200
      • a25rjr
        • 3774
        I thought your Six Pack crew "acquired" whatever parts you needed!
        Turn LEFT, Vote RIGHT!
        • Krooser
          • Nov 2012
          • 3117
          I wanna know Lonnie Anderson's bra size..
          Class of 2019
          • brewster baker
            • 30
            thanks 4 the answers it is hard to acquire parts with all them in closed trailers
            • hucktyson
              • 1903
              The flat tappet turning 8700 sounds like a great idea. I know the cup guys used to use the cams with the hard face overlay welded in and some super expensive lifters to pull that off. Do 23 degree heads even make power at 8700 ??
              • Punisher88
                • Nov 2014
                • 495
                It was only a split second I figured. I wanted it to launch off the corners so I hung a gear in it.
