Contraption? Getting Coolant up to Temp...
  • TheJet-09
    • Jul 2013
    • 1616
    So the night time weather is nice and cool in my neck of the woods now, which leads to blocking off the radiator to get the coolant temp up before pulling out onto the track. The issue I'm finding, is that by the time you sit in line for a minute or two, and pull out onto the track and sit even more getting lined up, the coolant temp is right back down to nothing.
    Has anyone ever seen, or thought about, a device that could be controlled from inside the c0ckpit that could block the airflow to the radiator? I'm envisioning something like a window blind, with either a cable or electronic motor, that could close the "blades" so to speak, then open them once up to temp. Risky if it fails, yes, but while racing my coolant stays around the 180* mark, so I'm not looking to alter the fan or anything like that.
    Could this be the next greatest thing, or has my "Willy Wonka mind" gotten the best of me? Or do the cylinders maintain enough temp that is not directly seen on the coolant gauge for me to even worry?
  • Krooser
    • Nov 2012
    • 3117
    Radiator shutters are still used today...I drive a 94 bluebird bus with a 5.9 Cummins that has an air operated shutter...
    Class of 2019
    • CCHIEF
      • Jul 2014
      • 399
      I know of a great contraption, and it is automatic.... it's called a thermostat! Proper Heating up an engine requires the oil temp to be close to the water temp.
      • TALON75
        • 887
        Not cheap but can be controlled from your seat.
        www.RACE91.com
        • fastford
          • 4059
          I have always ran a thermostat in cool weather with out a problem. I think the one I,m using now is an afco.
          • TheJet-09
            • Jul 2013
            • 1616
            All excellent suggestions. Thank you!
            • racer2e
              • Jan 2012
              • 54
              Buy the high flow thermostat. Afco, stant, Mr gasket all make them. I drill 3 small 1/16" holes evenly spaced around the body. This helps it purge air and avoid temp spikes. I usually run it all season, but I have pulled it out in hot weather.
              • fastford
                • 4059
                good tip on drilling those holes
                • TheJet-09
                  • Jul 2013
                  • 1616
                  I don't know why I didn't even think of a thermostat (duh!). Tunnel vision on my part I guess as I haven't run one in forever, at least that I can think of.
                  I've only checked out my local asphalt retailer and didn't see any listed. Is there a specific degree (temp) most of you are running, or do they only make one (like the Afco for example)? I also like that gadget TALON75 passed along.
                  And while on the subject, along with oil temp, is anyone running oil cooler integrated radiators? If so, was there a noticeable increase in coolant temp, or decrease in oil temp, as opposed to not running one?
                  As always, thanks in advance!
                  • RCJ
                    • Nov 2007
                    • 509
                    A lot of brodix intakes won't take a thermostat.
                    • CCHIEF
                      • Jul 2014
                      • 399
                      Best to keep oil coolers behind the engine for weight distribution and more so for protection from impact damage.
