Axle tube lengths
  • LIS20
    • 83
    Axle tube lengths
    What are the length of the axle tubes ( not axles) on a rocket - i called rocket and they gave me left 26 5/8 and 30 1/8 -- this doesn't seem right to me -- thanks in advance
    • 14319
    26 5/8 would be for a 32" axle. Sounds right for an older Rocket from what I remember. That would be a 32/36 rear.
    • petesbuyin
      • 56
      Those would be the correct length for the current Blue/Grey and the XR1's. With those lengths you will also need to run a 1" wheel spacer on the left rear as standard. That gives you the option to remove the spacer when the track is tacky to free the car up.
      A droop rule is like infield tractor tires, everyone knows it's stupid, but they still keep doing it.
