Is an 8" yoke what I need to use behoind a non ball spline Bert?
Bert Gen 1 yoke...
^^^ That's my understanding as well. I use the 8" yoke. I first had a 36" driveshaft, mainly out of fear based on the number of rear trans seals I blew out/destroyed back in the earlier days. But that was before I did any limiting of the LR travel. With that now, you should be able to tell exactly how far forward the driveshaft is going to go at full droop (LR) and pinion hike.
I have since went to a 37.5", because I was playing around with moving the LR back in the slick and didn't want to get too far extended (I believe MB calls for a 38" driveshaft). But I do know for certain, that with the trans I bought new in 2013, I can bottom the 8" yoke out in it (meaning the output shaft is splined long enough).
if you do have to rebuild it , here is a little money saving tip, the clutches and steels for a 1982 honda civic automatic trans work great , you can get them at about any trans supply company , last i bought , they were around a buck a piece , bert wants over a 100 for the set, and they work great , one thing though , let them soak in type f trans fluid for a couple days before installing them.Originally posted by Krooser View PostI've heard that... I'm looking at buying a Bert in the near future... Have to stay on budget so it will likely be one I'll have to rebuild so I'll look for those longer splines.
Thanks guys... I have two or three driveshafts so I will have to measure them to see what I have in stock. I figure an 8" yoke would be the best bet... if my shafts will work with it. If not I'll fire up the hacksaw and welder.
The Honda clutches are a good idea...
Now that I have your attention I've been looking for the post here that talked about converting the Toyota 22R starter to work with the Bert bell... anybody know about that? I remember most of it... and I bought a starter for $38.00 so I'm ready to get going.Member of the Luxemburg Speedway Hall of Fame
Class of 2019
