rocket springs
  • n4cgrt
    • Nov 2007
    • 65
    rocket springs
    I have a 2012 blue front rocket with raised cross member. currently has gray drop spindles on it. Was wondering what spring rates I should start out with? Running a banked 3/8 smooth slick track. Also are the gray drop spindles the same as club 29 spindles?
  • 7uptruckracer
    Need to get with current dual stage setup, or spring rubber setup. If you wanted generic baseline 450-500 LF 300-325 RF, 125 LR 250-275RR 250-325 5th at 38" (Match Rate To Motor) 120lbs bite and match left side weight 54-55 to track and motor as well as rear percent 53.5-54.5
