Bump Steer
  • happyhour
    • Jan 2011
    • 12
    Bump Steer
    I have a new Mastersbuilt in which had a BRT Rack, the car was set-up and raced twiced and Rack went bad and I replaced with a new Sweet Rack will this affect the bump steer or front end as a whole?? Help
  • BIGFREAK101
    • Apr 2011
    • 23
    Rack
    If all of the measurements are the same in physical mounting points ? No it will not matter but if you had to change some stuff to make it work the you need to check it out closer. GOOD LUCK
