where is the motor plate on a 2011 grt supposed to be mounted with a all aluminum motor. up, down, left, right. or what is a good starting point?
grt motor plate location
the info that we got from GRT on our G16 front end says and I would think it would be similar:
motor to the left for heavy or hooked up tracks
motor to the right for average to dry slick tracks
2nd hole from the top is standard location which requires 1/2" spacer under front motor mounts
raise motor when more side bite and weight transfer is needed.
The motor location info doesn't say about any difference between location for all aluminum vs steel
