Bought a 15 rocket, the right side 4 bar frame mounts have 2 sets of holes. Which set is standard holes? What would the bar lengths be for those? And when u move forward or back are u changing rod length or just moving the rear end for steer either in or out. Thanks
15 Blue front rocket question
15 rocket
Yes it does have rocket in the mounts. What are the standard rod lengths suppose to be?
Should be 18.5 on top an 15.25 on bottom if im not mistaken the just subtract what the distance is between the 2 sets of holes
im sure this has been asked before but what are the lengths of the lower control arms on a blue/grey front. Just need to check to see if mine are in the ball park. Also is there a standard length for one of the tie rods and set with the other? Thanks
